Hood Open Warning Light 98 xj8
Old Dec 10, 2013 | 03:13 PM
funcars's Avatar
Default Hood Open Warning Light 98 xj8
What is causing this, it has shut down the whole car, it will not start. Trunk will not open, but all doors are unlocked. Is there any way to open the trunk, I have tried the remote, the key in the trunk and it will not open??? I have made sure the hood is shut good. This is not a convertible, so I'm assuming the hood is the engine compartment cover lid.
Old Dec 11, 2013 | 08:11 PM
jagjunky's Avatar
don't have a direct answer for this....but it sounds like security module lock up/problem.try disconnecting neg. terminal on battery and than re-connect....this reset may allow you to get control over the car....
Old Dec 11, 2013 | 09:52 PM
chopr's Avatar
If the remote doesn't operate the trunk release, try the dash button. If that fails as well, use the key to manually open the trunk. You should find a small hole near the latching lever. At least you can reach the battery this way! Try the disconnect/reconnect idea. Works wonders!
Old Dec 11, 2013 | 10:05 PM
luc's Avatar
luc
Something wrong here. US specs cars do NOT have the alarm hood switch, therefor a open or close hood would make no difference
99xk8guy
Sep 29, 2025 10:51 PM
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
King Charles
Sep 3, 2015 12:40 AM
bkeats
E type ( XK-E )
Sep 2, 2015 09:38 AM
