Hood Release Problem
Old Sep 16, 2015 | 04:26 PM
dude1579's Avatar
Cool Hood Release Problem
Greetings! I was fortunate to have acquired a 1999 XJ8 with 84K miles. I have been very pleased with the vehicle until a recent (hopefully minor) problem. When I attempt to open the hood, only the latch on the driver's side unlatches and I am unable to open it. I presume it may be a busted cable, but I will defer the diagnosis to more knowledgeable Jag owners in the Forum. Any ideas on the cause of this problem and how to remedy it will be greatly appreciated.
Old Sep 17, 2015 | 02:20 AM
dude1579,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old Sep 17, 2015 | 05:01 AM
sparkenzap's Avatar
The procedure involves either making a hole in the wheel well or loosening the latches. Search forum for pictures and procedure for either side. If you cannot find it, check back.
If you decide to try the wheelwell hole method without the pictures, be aware that there are some major power cables there you might have an unpleasant encounter with!
Old Sep 20, 2015 | 03:24 PM
steven300's Avatar
if your brave put masking tape[3 layers] between hood and fender of stuck side.then remove grille.then remove 6 bolts of the hood hinge to radiator cowel,lift hood up enough to get cresent wrench on stuck latch.use two people.it wont be easy...steve
Old Aug 12, 2019 | 06:29 AM
aknovaman's Avatar
PM me your email and I can send you all the info you need.
H20boy
Dec 24, 2024 03:23 PM
99xk8guy
May 28, 2024 09:36 PM
WinterJag
16
Oct 9, 2015 07:49 PM
uncheel
Sep 5, 2015 01:34 PM
Jaguar Forums Editor
Jaguar Press release
Sep 3, 2015 09:38 AM
