How to adjust (raise) front bumper
Old Jul 27, 2009 | 05:17 AM
Mark Rogers's Avatar
Default How to adjust (raise) front bumper
I recently bought an XJ8 that had a slight front end collision. The hood and front bumper were removed. I'm in process of re-installing, but having trouble with alignment.
After installing the bumper, it appears it is about a half inch low in the front (it lines up with the fender in the rear, but hangs a little low, leaving more than a half inch between the grill and the bumper. Can this be adjusted?
There are two verical bolts (under the bumper chrome) that hold the font bumper to the two shocks (that bolt to the frame). Is this where the adjustment needs to be made? Does the bumper have to be removed or can it be adjusted while on car.
Thanks, Mark
Old Jul 27, 2009 | 12:00 PM
wazari's Avatar
The vertical bolts you mentioned are adjustable and affect the bumper height. I don't know of anyway to adjust those without removing the bumper.
Old Jul 27, 2009 | 02:38 PM
Wasari,
Thanks much for the response. I wanted to get some reassurance before I took the bumper off again. It sounds like fun, but I'll get it dialed in.
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
jdzubas
Oct 4, 2015 09:14 AM
avern1
Sep 6, 2015 04:22 PM
prettydaim
Sep 4, 2015 09:13 AM
