how-change-knock-sensor-jaguar-aj27-engine-faq-45963
Old May 8, 2012 | 11:40 PM
romajag's Avatar
Default how-change-knock-sensor-jaguar-aj27-engine-faq-45963
Can someone repost this guide or send it to me? The pictures are not opening. I have tried different computers and web browsers without any luck.
Also, any advice on the following codes:
PO300
PO305
PO316
PO332
PO357
PO1000
Thank you!
Old May 9, 2012 | 06:25 AM
test point's Avatar
It's not you. The link works fine but pictures are gone.
While we could post the diagnosis for your codes you would be better served to down load the JTIS file available in the sticky above. It has all the codes in a chart with the suspect issues listed in sorta order of frequency.
Old May 9, 2012 | 09:18 PM
jimlombardi's Avatar
Hi
Here is a brief description and diagram of the Location of the Knock Sensors (from the JTIS shop manual):
Jim Lombardi
Old May 10, 2012 | 07:10 PM
romajag's Avatar
I figured the pictures had been deleted but was hoping maybe someone had printed or saved it.
Will the knock sensor trigger the other codes or vice/versa? I guess I am asking what would be best to resolve first.
