How to clean MAF sensor on Jag XJ8?
Old Mar 29, 2023 | 11:08 PM
ericnunez's Avatar
Default How to clean MAF sensor on Jag XJ8?
Hello all I am trying to clean the MAF on my 2000 Jaguar XJ8 but I don't know if I should clean the intake tube as well with the CRC or just the sensor?
Old Mar 30, 2023 | 11:12 AM
RA110623's Avatar
Banned
Well if you know how to do it then great pull the air intake and clean the throttle with throttle body cleaner be careful from the throttle butterfly your finger may stuck there so use Large screwdriver to hold open and spray then wipe .
Excuse my English its my second language
Old Mar 30, 2023 | 01:13 PM
ericnunez's Avatar
No worries! Your english is fine! Thanks for your response. Is the throttle part of the air flow system?
Old Mar 30, 2023 | 04:03 PM
RA110623's Avatar
Banned
Yes make sure you install the throttle body rubber properly on the intake before you install it again because vacuum leak can make many problems. Let the maf dry then install change the air filter mahle good brand
Daim
May 17, 2016 08:58 PM
dcdecs
Feb 11, 2015 07:15 AM
jtp2
May 25, 2012 08:47 PM
Jon89
Mar 23, 2012 09:40 AM
cadrad
Jun 29, 2009 05:34 PM
