How do I bypass heater core?
Old May 25, 2013 | 08:50 PM
coastaljag98's Avatar
Default How do I bypass heater core?
I have a 99xj8 and I want to bypass heater core since I don't have the time to tear out the dash to fix the cold air bypass actuator. I'm getting heat and Ac thru same vents. Thanks
Old May 25, 2013 | 09:32 PM
test point's Avatar
No problem! Pick a place.
https://www.jaguarforums.com/forum/x...60/#post726405
Old May 25, 2013 | 10:53 PM
So if I disconnect the feed line to the Heater the one marked #5 in the diagram would that so it or which is easiest? Couldn't I just disconnect the feed and return lines at the heater core At the firewall and put them together??
X308XJR
May 20, 2019 06:50 PM
inactualis
Oct 2, 2015 11:13 AM
mrplow58
Sep 30, 2015 08:56 AM
magmedia
Sep 28, 2015 09:49 PM
