How do I change broken headlight / headlamp lens?
Old Dec 28, 2007 | 01:26 PM
drog321's Avatar
Default How do I change broken headlight / headlamp lens?
All - I have a 1998 XJR and I cannot figure out how to change the lens on the low beam driver side. It is shattered. I ordered the replacement lens (not the entire assembly).
I first removed the metal ring surrounding the light, additionally, I completely unscrewed the screw which is used to adjust the height of the beam.
The light is stuck on two remainingconnections. Cananybodyplease guide me on how to disconnect the two pieces for the old lens?
Thanks-DR
Old Dec 28, 2007 | 08:25 PM
jag_genius's Avatar
Default RE: How do I change broken headlight / headlamp lens?
open hood walk to front of car and grasp with two hands and pull straight to you .. but becareful can hurt yourself.. or you can usea pry bar to put between lens and bracket and push apart..
Old Dec 29, 2007 | 09:54 AM
drog321's Avatar
Thanks - that was difficult...and I had to pull so hard that i fell on my **** when it finally came off.
DR
afterburner1
Dec 16, 2015 12:12 AM
avern1
Sep 6, 2015 04:22 PM
sklimii
Sep 5, 2015 06:04 AM
laserguy
Sep 3, 2015 02:02 PM
XFR_Gold
Sep 2, 2015 12:24 PM
