How do you take this thing off??
Old Aug 8, 2023 | 03:50 PM
ericnunez's Avatar
Default How do you take this thing off??
I have never seen this before in my life and definitely do not have the adequate tool to remove it.
Old Aug 8, 2023 | 05:47 PM
aquifer's Avatar
You might check the glove box, the spare tire area, and the tool compartment in the engine bay. The tool is usually a special socket that fits the pattern. Otherwise maybe try an auto parts store. I've never used one on my own vehicle, so I don't know how specific the tools are. Hopefully you'll find it in one of those places.
Old Aug 13, 2023 | 10:05 AM
clubairth1's Avatar
Community Influencer
I remove and throw away the wheel locks as soon as I get the car.
Do you plan to run wheel locks?
If not any tire place can get them off in 5 minutes. It's a REAL common problem!
They won't use a key socket either so they are usually messed up when removed.
Old Aug 13, 2023 | 05:30 PM
mike32966's Avatar
You can buy a tool from somewhere like Amazon -
Twist Socket Set, Lug Nut Remover, Metric Bolt Stud Lug Nut Extractor Tool Kit With Center Punch Bar 1/2" Drive 17 19 21 22mm 5 Pieces PTSTEL - Amazon.com Twist Socket Set, Lug Nut Remover, Metric Bolt Stud Lug Nut Extractor Tool Kit With Center Punch Bar 1/2" Drive 17 19 21 22mm 5 Pieces PTSTEL - Amazon.com
If you don't have an impact then the trick to using the tool is tapping on the end to keep it engaged with the nut while using a breaker bar to turn it.
orangeblossom
Oct 18, 2022 04:45 AM
WatchGuy
Oct 1, 2022 05:53 AM
xalty
Sep 1, 2022 08:29 PM
Project8
XE ( X760 )
Nov 13, 2021 06:51 AM
XXXAngelXXX
Aug 31, 2016 08:41 AM
