How much oil do I use for a bore wash attempt
Old Mar 31, 2020 | 04:52 AM
Joe Enge's Avatar
Default How much oil do I use for a bore wash attempt
I can only find “some”. Are we talking about .5 ml or 50ml? I was going to order an eye dropper.
2000 xj8 vdp
thanks!
Old Mar 31, 2020 | 05:43 AM
King Charles's Avatar
Just enough to put a film on the walls.
Old Mar 31, 2020 | 06:25 AM
RJ237's Avatar
1 tsp. is enough. Then spin with the plugs out to distribute the oil.
Old Mar 31, 2020 | 08:07 AM
Joe Enge's Avatar
Thank you for the answers.
I assume its just engine oil, correct?
rj237- what do I spin to distribute the oil?
thanks!
Old Mar 31, 2020 | 08:42 AM
RJ237's Avatar
Hold the pedal to the floor to disable the injectors and turn the key to start for about 10 sec. before replacing the plugs. Lay a towel over the heads to avoid spraying oil everywhere.
Old Apr 2, 2020 | 01:21 PM
Joe Enge's Avatar
Thanks very much.
just got the belt on and crankshaft sensor in. So off to try this.
i got pissed at the mechanic shop and had it towed back home.
somehow they were running all the tests, which I had to pay for of course, and trying to start the car without a serpentine belt. Still not sure how that worked.
so for $1500 I got two tows, a new alternator and installation, and the original crankshaft sensor removed. What a deal!
Old Apr 2, 2020 | 07:55 PM
Originally Posted by Joe Enge
Thanks very much.
Reminds me of my car in paint last year, I explicitly explained that the car needed to be on the already set-up battery maintainer while sitting(all you have to do is plug it in). Not even 5 days later I get a call stating the car won't start, what he didn't tell me was that he tried numerous X to start it. So I had to travel to the shop, we explored inertia switch etc. Finally he tells me he tried numerous time to start using the gas pedal etc. I send him the detailed bore wash procedure from the forum here. He gets it started again & puts in new plugs. Then wants to tack the bore wash incident time & costs to the paint bill. I was like "No sir if you would've listened to my instructions(verbal,text,email) concerning the charger this wouldn't have happened, as it never has before in my tenure w/ the car. He's an honorable guy so he ate the plugs etc. cost but it really got me a bit perturbed @ the time lol.
Old Apr 3, 2020 | 09:38 AM
Joe Enge's Avatar
I love how some mechanics think that they know everything, and won’t listen to a non mechanic.
i spent yesterday putting everything together, even the washer solution container. Not sure why they took that out. Did exactly what I told them... though I admit I forgot to tell them that a serpentine belt had to be installed for it to start.
she purrs today!
pistons and timing chains my @ss!
thanks all, so very much.
Keltam
Sep 19, 2021 08:17 AM
Miss Charlee
Feb 15, 2016 06:17 PM
pezzonovante88
Oct 30, 2011 10:29 PM
kitty
Jun 8, 2009 05:01 PM
