How to remove the intake manifold and replace the heater hoses (with photos)
Old May 19, 2015 | 10:15 AM
daxter1987's Avatar
Default How to remove the intake manifold and replace the heater hoses (with photos)
I recently had to remove the intake manifold on a 4.0 liter V8 to change the cooling hoses that run from below it. I took photos and wrote the procedure for anybody who wants to do it.
Here is the link: jaghelp.com: How to remove the intake manifold and replace the heater hoses of your Jaguar XJ 4.0 liter
Any questions, please comment!
Old Nov 10, 2022 | 03:41 PM
schoeman's Avatar
Default What hoses connect where on reassembly?
Thanks a million. Could never have done this without the forum. I'm in final reassembly, and I have forgotten what goes where on a couple of items.
  1. What hose connects to the larger pipe on the rear of the throttle (top picture, circled in yellow).
  2. What hoses connect to the two smaller pipes (red and pink)? My guess is that the pink one connects to the hose going to the plastic T fitting on the end of the Octopus hose, and the red one connects to the metal stub (lower photo, circled in yellow) alongside the mounting bracket for the throttle elbow.
Thank you for your help. I now know not to trust that I will remember where things went when the time for reassembly comes!
Old Nov 10, 2022 | 08:39 PM
schoeman's Avatar
Default Where does this hose connect from throttle elbow?
Trying to put car back together after intake manifold removal. Last mystery hose -- connects to stub on throttle elbow labeled "Fuel Tank Vacuum and Pressure Relief Valve Connection" in drawing below:
Actual photo is below (elbow is upside down). Hose is about 18 inches long, looks about 1/4 inch, black soft rubber with white stripe. What does it connect to on the other end???: THANK YOU!
Old Nov 11, 2022 | 06:19 AM
Addicted2boost's Avatar
I’m pretty sure it goes to the vapor canister purge on the firewall.
Old Nov 11, 2022 | 09:05 AM
schoeman's Avatar
Cool THANK YOU
Thank you thank you thank you! I think that was the last mystery connection -- now for reassembly. I am in Naples -- if you are nearby, I'm always happy to help! (and learn)
Old Apr 23, 2023 | 06:37 PM
jessquirl's Avatar
Default Your link doesn't take me to any repair stuff????
Old Apr 24, 2023 | 07:36 AM
schoeman's Avatar
Default Throttle Hose repair procedure from jaghelp.com
The link seems to be broken, but when I did the repair I printed a pdf of the instructions (which are excellent! Thank you jaghelp! I take no credit of course) which I have attached. I hope it helps -- it did help me! Good Luck, and Bon Courage!
Old Apr 24, 2023 | 07:51 AM
schoeman's Avatar
I'm not sure the pdf file attached correctly, so here is a link to it: https://www.siftj.org/misc/jaghelp.pdf
Old Apr 25, 2023 | 02:45 PM
sdblacksheep's Avatar
Thumbs down Do not click the link - goes to unrelated sites including dating
I clicked, asked me to install extension, which I stupidly did, took me to Army website, the to dating website!!!
Old Apr 26, 2023 | 10:39 AM
leaddog11's Avatar
thanks
Old Apr 28, 2023 | 09:55 AM
leaddog11's Avatar
could heater hoses be just moved to top of manifold without removing manifold.?
Old Apr 28, 2023 | 09:56 AM
leaddog11's Avatar
Old Apr 29, 2023 | 06:36 AM
You must remove the intake manifold, there is no other way around it.
DevonDavid
Oct 5, 2025 08:19 PM
Joe Enge
Nov 2, 2022 10:55 AM
Bob Boyle
Mar 9, 2021 09:28 AM
EZDriver
Jun 22, 2020 03:48 PM
Bowmanconsult
Apr 20, 2012 04:02 PM
