How to replace part load breather hose?
Old Sep 26, 2014 | 07:59 AM
vdpnyc's Avatar
Default How to replace part load breather hose?
Just ordered a replacement part load Breather Hose. How do I connect to the throttle body side without removing the whole throttle body?! Just channeling it down the length of the engine-block looks tedious...
Old Sep 26, 2014 | 09:10 AM
cobac's Avatar
When I replaced mine, I had a problem getting the connection at the throttle body disconnected and decided to cut it off. I figured since it was cracked and I was replacing it anyway this was the easiest way.
Then to run the new hose, I taped the new hose to the old hose at the front of the engine and fished it under the intake manifold to the back.
Just a note, to get the new connection onto the throttle body required a good push for it to click in. The rubber hose on the purge valve was also really fun to disconnect.
RaceDiagnostics
Dec 11, 2015 10:12 AM
Xj812
Oct 26, 2015 05:04 AM
Ophitoxaemia
Sep 14, 2015 02:40 PM
casepie
Aug 30, 2015 09:49 PM
daro31
Aug 27, 2015 09:26 AM
