i have a 2003 jaguar model s . the battery is dead .
Old Jun 10, 2018 | 11:04 PM
mazenc83's Avatar
Default i have a 2003 jaguar model s . the battery is dead .
the battery won't take a charge. when I tried to remove it, the battery cables came off ok and the bolt holding the steel hold down rod to the fender well came off ok . but the real long bolt on the other side will not come loose. it holds the other end of the steel rod and the plastic piece holding down the bottom of the battery. I tried wd 40 several times. I tried taping the bolt head and several other things, with no results. any suggestions ? thanks, russ
Old Jun 10, 2018 | 11:14 PM
Daim's Avatar
Give the guys in the S Type Forum a chance as this is the X308 XJ section (totally different car, totally different plattform, totally different design)
NurseD
Feb 19, 2022 08:45 AM
JWheaton10
Jan 19, 2020 09:55 AM
wannoa
Jun 1, 2018 05:30 AM
wannoa
May 19, 2018 05:22 AM
bocatrip
Apr 10, 2018 04:35 PM
