Idler Pulley?
Old Feb 6, 2022 | 11:26 AM
Dreamjags's Avatar
Default Idler Pulley?
High pitch whine on cold starts from the front of the engine.
Old Feb 6, 2022 | 11:28 AM
Dreamjags's Avatar
Accidently posted before I was done if I am correct is this an easy DIY for someone or a PITA? Also can I drive the car or should it be fixed right away?
Old Feb 7, 2022 | 08:35 AM
Jtestrake's Avatar
It’s not difficult. You can but a new idler pulley from Rockauto.com or Partsgeek.com. After removing the serpentine belt, the idler is attached to the timing cover by one (13mm?) bolt.
Old Feb 7, 2022 | 09:54 AM
clubairth1's Avatar
Community Influencer
First remove the belt and start the engine for a few seconds to make sure where the noise is coming from. Hate to see you replace parts and not fix the problem.
If you do replace it also replace the belt and check very carefully all the other pullies. If one has worn out all the others have exactly the same number of miles on them.
Your noise could just be an old worn belt.
But with a 2000 year 4.0L V-8 your number one concern would be the timing tensioners. Have they been replaced?
MuttonJohn
Jun 14, 2021 04:30 PM
ashbypa
Mar 23, 2017 07:28 PM
mcook
Apr 10, 2016 11:53 AM
maxwdg
Apr 7, 2013 04:30 AM
Robert Page
Feb 18, 2013 05:54 AM
