Instant fuel consumption readout.
Old Mar 10, 2011 | 03:29 PM
johnco's Avatar
Default Instant fuel consumption readout.
As fuel prices are rising I have been taking a greater interest in my fuel consumption and have been looking at the instant fuel consumption readout.
When I am cruising downhill between 40 - 80 miles an hour when I lift my foot off the accelerator I notice the readout goes something like this :- 37.3 43.7, 54.6, 63.7, 70.2, 68.6, 73.7, 19.9,14.5,19.9, 70.2 etc.
Is it normal for the fuel consumption to suddenly drop like this? It can also seem to happen on the level but there is not such a large fall in consumption for apparently no reason.
Any ideas what could be causing this?
Old Mar 10, 2011 | 04:08 PM
Brutal's Avatar
Under high vacuum no load pulse width to the injectors is just about cut off and depending on the speed youll see numbers up to 99mpg...normal
take a picture and tell everyone you installed a water to hydrogran brown gas convertor and look at the mileage you get. (i saw a guy last time $4/gal hit and he was trying to see those systems)
Old Mar 10, 2011 | 04:19 PM
vdpnyc's Avatar
Haha, in NYC stop-and-go mine is usually fluctuates between 7-8mpg and 50-60, typically hovering in the 11-16 range!
Old Mar 10, 2011 | 04:28 PM
Stu 1986's Avatar
I use the average fuel option as it gives me a better idea of what the car is doing. Instant is a bit too quick changing.
Old Mar 10, 2011 | 04:37 PM
johnco's Avatar
Hi Brutal
I understand why the mpg would appear high but what I don't understand is why with no accelerator it should suddenly drop to say 15 mpg and lower on occasions
Old Mar 10, 2011 | 04:44 PM
plums's Avatar
Quite true. However, the instant readout is a good tool for new owners to train their right foot.
Old Mar 10, 2011 | 04:51 PM
Brutal's Avatar
Originally Posted by johnco
hi brutal
i understand why the mpg would appear high but what i don't understand is why with no accelerator it should suddenly drop to say 15 mpg and lower on occasions
probobly cause the ecu will control rpm and pulse width for condition like power steering need, trans downshifting/upshifting, ac, etc and blip rpm up or increase pulse width momentarily. I really wouldnt put too much thought into it. Those just like ext temp are calculated algorithymes and not always exact.
Old Mar 10, 2011 | 07:29 PM
burmaz's Avatar
At least the instant mpg on these cars aren't space consuming and pointless like those in BMWs. I never understood why they have that gauge. All it does is constantly move left and right while reading on a scale that is faaarrrr from linear. If you have driven a BMW, you will know exactly what I'm talking about.
I guess a gauge that can move more rapidly than a tachometer is kinda cool?
Old Mar 10, 2011 | 08:33 PM
QuadManiac's Avatar
Was your A/C on (or defroster, or even in Auto mode)? The compressor cycles on and off, and the ECM will increase idle fuel supply slightly when it cycles on - at the initial turn on load it could drop the instant fuel consumption briefly.
Old Sep 7, 2013 | 08:59 AM
PaulXJ308's Avatar
Default Me Too!
I have an XJRV8 (2000). I only get 16mpg or so in mixed driving and I have noticed exactly the same fuel wastage when off the throttle going down hill.
I have no obvious engine issues. I had an o2 sensor replaced recently but poor economy persists.
Did you ever get to the bottom of what was the cause?
Old Sep 8, 2013 | 06:29 AM
fredd60's Avatar
Default instant fuel readout
Probably the ECM is programmed to inject fuel occasionally to maintain temperature in the cats, as they can produce rotten egg smell in that situation.
Many years ago, when cats were first fitted to cars, residents who lived at the bottom of a very long downhill road in Sydney, Australia, complained of a constant smell of rotten eggs. Seems that car manufacturers switched off fuel injection on the overrun, to achieve better fuel economy. Cool cats= rotten egg smell. Legislation was passed to worsen the fuel economy of every car sold in Oz.
GGabriel
Nov 22, 2018 03:53 AM
moff1959
Sep 26, 2015 05:35 PM
XKE73EIconverter
Sep 26, 2015 10:21 AM
reb1999
Sep 26, 2015 08:41 AM
reb1999
Sep 25, 2015 10:00 AM
