Interior illumination...how many bulbs can burn out?
Old Jan 27, 2014 | 07:53 AM
motorcarsrandy's Avatar
Default Interior illumination...how many bulbs can burn out?
Over the weekend I realized i had no j-gate illumination or cruise switch. I know you can solder in new lighting module bulbs but what about cruise switch bulb? Does it have to be replaced?
Then this morning my Rear fog "on" led went out in switch. Cant tell if on or off.
Already replaced inst cluster bulbs. I guess it is time for them all to fail.
Old Feb 10, 2014 | 06:43 PM
Bilklan's Avatar
Is this on an xj8? The whole left side of my cluster doesn't light up! Bulbs likely, but is it easy to access them? Thanks
Old Feb 11, 2014 | 05:15 AM
I had instrument and shifter gate . All started faILING AT SAME TIME.
Old Feb 11, 2014 | 06:45 AM
kyle04's Avatar
If you're refering to the speedo / rev counter instrument display you have 1 or 2 bulbs gone.
Easy enough to remove the instrument pack and replace - there are a few posts about this.
All you will need is a magnetic philips screwdriver and a pair of pliers.
With the pack removed the larger bulb holders (there are 4) can be removed by twisting anti-clockwise with the pliers. The bulbs can then be pulled out and replaced.
You will need the 504 3W type push in bulbs which cost pennies. You may as well replace them all while you're there.
Disconnect the battery -ve terminal before comencing.
AndyP
ericjansen
Dec 19, 2021 12:20 AM
afterburner1
Dec 16, 2015 12:12 AM
Davidvdm
Oct 7, 2015 03:18 PM
avern1
Sep 8, 2015 06:25 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
