Intermittent issues turning over
Old Jul 16, 2011 | 09:28 PM
Scottish Chap's Avatar
Default Intermittent issues turning over
Hey guys - 1998 XJ8 VdP with 53K miles is doing well, but every 4th or 5th time I start the engine, it turns over a little hard (takes maybe 2-3 secs or so but always starts). I notice this only if I have driven the car a short distance, and then try to start it withing a couple of hours - never if the car has been left for a day or two. It will also only do it once that day. If I stop and try to start the engine again right away, it will always start quickly.
Other than the obvious: checking battery voltage etc, anything else I should be doing? Could this be a spark plug issue? I'm new to Jaguar. What a great car! Many thanks in advance!
Old Jul 16, 2011 | 09:41 PM
motorcarman's Avatar
Wrong forum here but it sounds like a slight vapor lock problem (fuel return check valve leaking slightly or a 'dribbly' injector). Put a fuel pressure gauge on the fuel rail and watch the pressure after 'shutdown'.
bob gauff
Old Jul 16, 2011 | 09:52 PM
bob gauff
Sorry for posting in the 'newer Jag' forum (Mods - please feel free to move this over there).
Please explain this to me like I am a two-year-old. If what you suspect is the case, how much damage can this cause the car, and what would I be looking to pay a third party to repair this, as I have limited equipment? Thanks once again.
Old Jul 17, 2011 | 03:03 AM
Cadillac's Avatar
Moved , thanks motorcarman for his help as well
Old Jul 17, 2011 | 11:51 AM
Thanks for moving. Would really appreciate insight from others, too, regarding the above. Thanks, guys!
Old Jul 18, 2011 | 07:59 AM
Here are some things to check. Time for some diagnosis.
Let us know what you find.
bob gauff
File Type: pdf
File Type: pdf
Old Jul 18, 2011 | 07:43 PM
bob gauff
Thanks, motorcar man!
No problems turning for days...until I tried the experiment today. Car was driven around 10 miles earlier today (say 2 hrs ago) - went to turn it on, and it took 2 secs to turn over with a little trouble as it has been doing on occasion, but it turns. Now the experiment: I ran at ~2000 rpm for a minute, let it idle, turned it off, left it for 60 minutes, then turned over just fine. Now I am confused.
Sticky injector? Any utility in an injection cleaner instilled into a near empty gas tank?
Wolfy
May 28, 2024 08:06 AM
JarodL
Mar 7, 2024 01:39 AM
laserguy
Sep 3, 2015 02:02 PM
XJsc-guy
Sep 2, 2015 11:43 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
