Intermittent non-cranking issue
Old Apr 23, 2018 | 12:38 PM
dhardison's Avatar
Default Intermittent non-cranking issue
'02 XJR - Brought the 'ole girl out from her Winter slumber and now after 10-15 successful starts I'm having intermittent non-cranking issues.
Brand new battery, no codes, but occasionally (and becoming more frequent) I'll turn the key to the crank position, and nothing (post successful system check). If I turn the key all the way back and try again, sometimes it works and sometimes it takes 2-3 attempts.
Ignition switch maybe? Any suggestions on what to troubleshoot first?
**EDIT: I've found some good info in the following thread, but it points to a lot of possibilities.
starter relay
ignition key replacement/re-program
exciter ring
trans interlock
https://www.jaguarforums.com/forum/x...-problem-9439/
Thanks,
Dan
Old Apr 23, 2018 | 02:46 PM
Highhorse's Avatar
A review of this may assist.... https://www.jaguarforums.com/forum/x...-start-199071/
DesertXK8
Dec 10, 2016 09:11 PM
Tman
Aug 23, 2015 06:56 AM
bazanaius
Aug 22, 2014 04:18 AM
Valguard
XJ40 ( XJ81 )
Nov 24, 2013 08:36 AM
robhair
XJ40 ( XJ81 )
Feb 18, 2012 10:09 AM
