issues with piston rings XJR v8
Old Mar 2, 2022 | 01:22 PM
Wildcat_nl's Avatar
Angry issues with piston rings XJR v8
Dear gentlemen, gentlewoman,
I've been busy last months getting all the parts for rebuilding my engine (4.0 AJ26 s/c). All parts that wear down are going to be replaced.. Valves, valve seats, crankshaft bearings, some broken pistons, piston rings, all gaskets etc etc.
The bed plate has already been united again to the engine block, with the beautiful Loctite sealant. Now I want to install the pistons, but I've ran into some issues getting the compression piston ring inside the bore.
piston ring type
The rings that I'm using are Mahle original JLM20929 (pic above), but I've tried about everything I can think of, ring upside down, piston upside down into the bore, leading with empty piston, giving it a goodnight kiss, tightening the piston ring compressor until blood came out.. nonetheless, nothing worked. The 2nd piston ring (wiper ring) is the same size as the compression ring and does go in normally. The OD of the compression ring is also the same as the original rings that came out, only the ID is larger.
Has anybody experience with the piston rings that I have getting them inside the engine block? If so, could it be my piston compressor (pic below)?
Thank you all!
Old Mar 3, 2022 | 03:15 AM
Jeroen's Avatar
Can you get the ring in by itself? So test fitting it in the cilinder without the piston? On the odd occasion the two ends of the ring touch each other and the ring simply would not fit into the cilinder.
Jeroen
Old Mar 3, 2022 | 03:22 AM
Wildcat_nl's Avatar
Hi Jeroen,
When I dry fit the piston rings they have a visible gap, around 0.4mm.
Old Mar 3, 2022 | 03:28 AM
Jeroen's Avatar
Originally Posted by Wildcat_nl
Hi Jeroen,
sounds about right, very odd. Only other thing I can think of, is to measure the ring groove inside diameter and depth and compare with the old piston, see if anything differs.
Old Mar 3, 2022 | 06:13 AM
Wildcat_nl's Avatar
Hi Jeroen,
Will try that tonight when I get home from work
Old Mar 3, 2022 | 02:22 PM
Wildcat_nl's Avatar
Hi Jeroen,
I placed the piston ring on the 2nd place (middle) and it does fit within the bore, so that's nice to know.
I'm going to adjust my clamping tool with an angle grinder and see if that will work.
Also, I saw that you're located in Spijk. Greetings from your 'overseas' neighbor in Arkel
Old Mar 3, 2022 | 03:54 PM
Wildcat_nl's Avatar
Hi Jeroen,
So I managed to make it work, my hacky angle grinder job did it's job. I placed the clamping portion closer to the edge by grinding the steel rivets away and moved it all 1 position down, then riveted it back.
As I accidently managed to damage piston number one by trying harder yesterday I will get an replacement one, but number 2 fit in without any effort this way.
Old Mar 3, 2022 | 05:31 PM
Addicted2boost's Avatar
Where are you getting a replacement piston from? I can’t imagine that’ll be an easy find. Also, is it my imagination or does the top of that #2 cylinder wall look scraped up? I don’t think you can use a hone for that nikasil coating.
Old Mar 3, 2022 | 06:12 PM
Wildcat_nl's Avatar
I know someone who has an engine with grade 2 pistons, got already 3 of them because my piston glands were f'd up.
F'd pistons (all broken metal was still nicely in between like an jigsaw for engineers)
The "scraped up part" is actually an reflection of the thick 20w50 oil that I'm using for assembly
Old Mar 4, 2022 | 12:12 AM
Jeroen's Avatar
Good to hear you managed to make it work. So it was just the clamping tool that was not compressing the rings sufficiently!
Jeroen
Old Mar 11, 2022 | 02:17 PM
Vauxi's Avatar
I never ever use that type piston ring compresser tool anymore. Went and tryed one time tapered adjustable aluminium piston ring compresser tool and never going back. It was so close to broke of 50 yo NOS piston rings that I had to look out for other tools.
https://www.proformparts.com/product...minum-material Like so.
Old Oct 13, 2022 | 09:05 AM
DJB XJR's Avatar
Hi Wildcat,
Did you manage to find details on the allowable clearances and tolerances between the piston diameter and the bore diameter?
The engine repair course Doc. states the following:
But if both bore and piston are grade 2 then the piston could be bigger than the bore!! Unless I'm missing something?
If you have the clearance/ tolerance specifications I would love for you to share them please.
Old Oct 18, 2022 | 09:14 AM
Wildcat_nl's Avatar
Hi DJB XJR,
I have the same document as yours, only the original PDF. Eventually, I discovered that the new piston rings available for sale (the mahle ones I showed in the picture) are wider than the original older ones. So I found a scrapped engine from 2001, with grade 2 pistons where the grooves are deeper. That worked like a charm.
I still have the old pistons lying around, I can measure the groove depth for you if you want me to.
Kind regards,
Wildcat
Old Oct 18, 2022 | 09:24 AM
RandyS's Avatar
Yes... that one provides much better insertion technique.
Markel
Sep 10, 2020 01:19 PM
Smokeyone
Aug 24, 2018 09:50 AM
monicagregory
Jun 21, 2013 11:45 PM
willy-k
Feb 28, 2010 06:14 PM
