Jag. Service Tech: Please Help!! (brakes)
Old Jan 21, 2009 | 06:31 PM
idorace's Avatar
Default Jag. Service Tech: Please Help!! (brakes)
I have got a 2003 XJR w/o the Brembo option. EBC says that 2002 and 2003 front rotors are different (they don't make them for a 2003). My local auto parts store says they are the same. The local Jag, dealer can't tell me if there is a difference without VIN numbers.
Are they the same, or are they different?
Old Jan 21, 2009 | 08:11 PM
jhe2003's Avatar
Default RE: Jag. Service Tech: Please Help!! (brakes)
Don't remember exactly wich years but there isthree different size rotors
Supercharged car with brembos
*Supercharged car non brembos
*Except supercharged car
If you don't want to run around back and forth I would take the rotor off and take it to the dealership!! IMO
Old Jan 21, 2009 | 10:27 PM
idorace's Avatar
I want a set of EBC's. You are right, three different sizes. Non Brembo XJR's are 325 mm. The question is are they the same from 2002 to 2003?
Old Jan 21, 2009 | 10:28 PM
Brutal's Avatar
measure the diameter of the rotor
Old Jan 22, 2009 | 06:23 AM
jaggachafen's Avatar
In europe the 2003 model was the x350 the new aluminium XJ but i\ve seen that you have 2003 model x308 in the US if it`s an x308 body there are the same on 02 and 03 EBC is a brittish company and therefore they will end the x308 range at 02
If you have an x308 the discs for a 02 model would fit your car. If you have an x350 they wont`t
Old Jan 22, 2009 | 11:00 PM
idorace's Avatar
Thank you, finally an explanation that makes sense. Mine is a 308.
jdzubas
Oct 4, 2015 09:14 AM
Jefro
Sep 15, 2015 01:44 PM
SeanU
Sep 13, 2015 02:45 PM
MrMellor
Sep 7, 2015 10:22 AM
Numwen
Sep 6, 2015 12:30 AM
