jaguar recall?
Old Mar 12, 2007 | 12:58 PM
bigdreams05's Avatar
Default RE: jaguar recall?
The most probable thing is a faulty power cable on the fuel pump which wont pump blood to the heart it the fuel pump doesn't have power going to it. The ground is just as important a connection to the pump as is the power cable so watch for both!
Old Mar 29, 2007 | 08:55 PM
Envy337's Avatar
Remove the intake tube going to the throttle body. Check to see if you have a black build up around the throttle plate. If so, clean it
off with throttle/carb cleaner and a rag. Disconnet the battery for a few minutes, turn it on, let idle till it reaches operating temperature.
If it doesnt fix it, you have bigger problems [:@]
Old Apr 1, 2007 | 12:04 PM
Envy337's Avatar
Do you guys not read what I am saying???????[:@]
Throttle plate gets STUCK. It does not let enough air in and floods the engine. CLEAN the plate.
Old Apr 2, 2007 | 11:00 PM
Envy337's Avatar
The car will start in Neutral.
JarodL
Mar 7, 2024 01:39 AM
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
jdzubas
Oct 4, 2015 09:14 AM
David Thompson
Sep 3, 2015 07:48 PM
