Jaguar x308 2001 xj8 3.2 sport
Old May 13, 2020 | 03:27 PM
umbrelaman's Avatar
Default Jaguar x308 2001 xj8 3.2 sport
I have a constant dashboard light indicating "Restricted Performance" Acceleration dies around 3000 revs. Diagnostic codes P0332 "Knock/combustion vibration sensor2 circuit Low Bank2. Any advice please?
Old May 13, 2020 | 04:00 PM
Highhorse's Avatar
Knock sensor, ...buy...replace...drive happy
Old May 13, 2020 | 04:03 PM
umbrelaman's Avatar
thanks for that! would I check connections, cable conditions first?
Old May 13, 2020 | 04:12 PM
Highhorse's Avatar
Hehehehe, j/k brother....
Almost guaranteed its the sensor, but it could be a connector.
Here's a vid to review...
Old May 13, 2020 | 04:24 PM
RA110623's Avatar
Banned
I had same exact problem fixed by changing the sensor . Here's sensor that's compatible with ur car
D​​​​​SU7015 or SU7012
Airtex 5S5619
Standard Motor Products KS309
Denso LNE1692AA
Old May 13, 2020 | 04:34 PM
umbrelaman's Avatar
Thanks for that
Old May 14, 2020 | 03:10 PM
umbrelaman's Avatar
Thanks for the heads up gents! looked at the connectors and cleaned off before a good dose of wd40. Cables all looked clean with no sign of corrosion. The car hadn't been used for a time so took for a run around town. Built up speed slowly keeping the revs below 3000rpm, no problems right up to 70mph. Slowed down & increased throttle through 3000 and got same jerky reaction. Stopped and filled up with fuel, left the service station and noted shortly afterwards that the 'limited performance' warning had gone. Drove 60 miles without a problem taking her right thro' the range up to max revs.
Old May 14, 2020 | 05:33 PM
Highhorse's Avatar
Sounds like an intermittent failing sensor.
Mrjay622
General Tech Help
Jul 9, 2019 09:21 AM
RyanTheRhino
US Southwest
Jul 11, 2018 01:33 PM
Streambed
Feb 15, 2017 03:31 PM
Stu 1986
Aug 15, 2011 04:13 AM
