Jaguar xj se 308
Old Jul 10, 2012 | 11:34 AM
redbull's Avatar
Default Jaguar xj se 308
The warning lights on my jag have all started to appear, even though the car is working fine.
bonnet open
abs fault
dsc not available
gearbox fault
Air suspension fault
vehicle too low
The speedometer has stopped working
engine managment light
brake warning light
I would like to get the car fixed at the local dealership but i have heard a few horror stories regarding Jaguar 308 electrics taking days to diagnose and repair. the air suspension has now stopped working, any advice welcome
Old Jul 10, 2012 | 02:33 PM
avt007's Avatar
I'd check the false bulkhead connector, the engine grounding strap, and the battery. Low voltage can cause all sorts of weird issues.
Old Jul 10, 2012 | 04:36 PM
mrlovt's Avatar
+1 to Rob's advice. You have several unrelated systems suddenly indicating faults, but they all share the same voltage and ground. Have the battery checked for amps (CCA) as well as voltage.
Old Jul 10, 2012 | 07:21 PM
OldMike's Avatar
+2 check battery
Old Jul 11, 2012 | 02:57 AM
redbull's Avatar
Thanks for the replys, i have misquoted my car as the 308 , i am fairly sure its the xj 6se 350 aluminium body with air suspension.
Old Jul 11, 2012 | 12:44 PM
TerryR's Avatar
I have a 1999 XJ8 and recently had it to the dealership to resolve the final 2 electrical issues I had. I was quite suprised to find that they will diagnose your problem, and give you an estimate for repair for a standard charge of $130 +tax. In my case, I let them repair, as I did not have the facilities or time to do it myself.
Old Jul 11, 2012 | 02:27 PM
mrlovt's Avatar
What year and location is your car? The x308 was sold in the US through MY 2003, the X350 beginning with MY 2004. In Europe the X350 began selling with MY 2003. In any case, you should still start by looking at the battery and ground.
Old Jul 24, 2012 | 03:22 AM
redbull's Avatar
Default problem solved
The problem with my jaguar has been diagnosed and fixed by the Jaguar dealership in Aberdeen. The problem was a badly corroded earth strap behind the nearside headlight
JarodL
Mar 7, 2024 01:39 AM
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
David Thompson
Sep 3, 2015 07:48 PM
bkeats
E type ( XK-E )
Sep 2, 2015 09:38 AM
