Keyless Remote Transponder
Old Dec 18, 2008 | 12:47 AM
Leaper's Avatar
Default Keyless Remote Transponder
I've found several Keyless Remotes for Sell on Ebay for my Model of Jaguar. ( 99 XJ8 ) I was wondering, before I buy one, if anyone could walk me through the process of coordinating it with my Vehicle and how to do so etc...or do I strictly have to go to the dealer??? I would really like to pull this off without having to, as I said, the dealer is three hours plus away...grr Anyhoo, I would really appreciate all the kind help!!! Thanks.. See samplelink: http://cgi.ebay.com/ebaymotors/97-00...1%7C240%3A1318
Old Dec 19, 2008 | 09:05 AM
Earl Filter's Avatar
Default RE: Keyless Remote Transponder
You can program it yourself. The instructions are here somewhere if you search. Takes all of about 3 minutes.
Old Sep 5, 2013 | 03:14 AM
Graham Royls's Avatar
Need some help here programming for 2001 XJR
Have brand new fob , all numbers match .
Have gone thru complete cycle . After the 4 flashes get red light and beep
I now have to push fob button 10 times and then get a "double chirp".
Is this indicating a connection ?
Is 10X normal?
Old Sep 10, 2013 | 09:58 AM
smtguy's Avatar
I have the same car and model year. Have all keys present. Here is the procedure I used:
2001 XJ 1. Open drivers door
2. Hold the highbeam selector arm towards you
3. Insert ignition key and key to first position (acc)
4. Release the high beam selector and then pull and release the high bean
selector 4 times.after the 4th time you will hear a chime.
5. Then press the lock button on each remote to program it in.
NCJagman
Dec 24, 2015 05:13 PM
Swagguar
Sep 30, 2015 01:34 PM
zdrapec
Sep 25, 2015 05:49 AM
kevinl
Sep 24, 2015 08:25 PM
