keys locked in boot x308 thinking of drilling hole but need to know right position an
Hi paulb123. I had this problem a while ago and you can get at the mechanism via the boot behind the number plate. here's the thread I started and the answers I got https://www.jaguarforums.com/forum/x...rouble-168502/
I cut a hole out in the end as a small nut had lodged itself down in the lock, see from post #11, there's some pictures that might help you?
Good luck with it, it can definitely be opened from behind the number plate using the measurements in my posts, my pictures also show which control is which (electric or manual key opening).
Paul
Paul
Paul
Paul
Have you given any thought to calling a locksmith, the Jag dealer? If the thread doesn't help, I can get pics of a couple of XJ8s in a local junkyard with the boot torn open to get the lock open.
Paul
Paul
Been locked out for around 3 months. Phoned Jaguar ages ago they said they could cut a key from the information on log book but the cost was over 120 quid. The locksmith couldn't do it with the tools he had so I thought I was stuffed.
I'm keeping the Jag on the driveway at moment and using the other one so there was no real rush and I was very reluctant to take a drill to it but i'm glad I did now. It's only a small hole and can't be seen anyway behind the number plate.
Thanks a million , Paul Bennett.
aholbro1
Oct 14, 2019 11:11 PM
migrosmarket
May 9, 2015 04:22 PM
