Knock sensor codes P0327 & P0332
Old Nov 16, 2015 | 02:49 PM
Miss Charlee's Avatar
Default Knock sensor codes P0327 & P0332
I replaced my thermostat housing and thermostat on vehicle. Now "Restricted Performance" and engine is displayed. This communication was not displayed before I changed the thermostat housing. What's the problem
Old Nov 16, 2015 | 03:34 PM
RJ237's Avatar
It's possible the knock sensors got a bath when you changed the housing. They are located under the intake manifold, and I think you will have to replace them.
Do a search for knock sensors and I believe you will find lots of information.
Old Nov 16, 2015 | 03:35 PM
avern1's Avatar
Most likely when you changed the thermostat housing you allowed water to run onto the area beneath the intake manifold. Water is probably sitting on the knock sensors and shorting them.
You can try compressed air from a tire air hose blow drying the underside of the manifold. If it has been a few days and some driving time then the water is probably already gone and the damage to the knock sensors has occurred. The knock sensors are mounted in the valley area beneath the intake manifold.
Old Nov 16, 2015 | 05:11 PM
Default Knock Sensors P0327 & P0332
Thanks for your input and suggestions. The knock sensors did get quite a bath, so I will probably have to replacement them both. FYI, I order my parts for Olivia from PartsGeek.com. They have great quality parts and you get your parts within a weeks time. Check them out.
xjr2014_de
Dec 7, 2015 06:26 AM
slownlo
Nov 5, 2015 05:38 AM
Mbeyda1
Nov 4, 2015 05:42 AM
Topsales1
Oct 30, 2015 02:39 AM
NS2000XKR
Oct 26, 2015 05:42 PM
