Knocking sound XJR X308
Old Jun 2, 2021 | 11:32 PM
faisme111's Avatar
Default Knocking sound XJR X308
Hello all, I have a 1999 XJR X308. I was on my way to an appointment and noticed as I accelerated I could hear a slight knocking as my revs went up. The knocking is not present at idle and goes away at the shift points. I had no oil pressure light or overheating. I was about 2 quarts low when I checked. When I filled up the oil and started it again I heard a loud metal to metal sound. I drove about 5 miles and only heard the knocking as I reached the shift point. Any ideas?
Old Jun 3, 2021 | 08:30 AM
motorcarman's Avatar
Please tell us that you checked/replaced the timing chains/guides/tensioners in the engine.
Old Jun 8, 2021 | 10:53 PM
faisme111's Avatar
Yes, when I had the SC off I replaced the cam covers and checked the tensioners.
This is the only close-up i took, it's the left side.
Old Jun 8, 2021 | 10:58 PM
faisme111's Avatar
It's also knocking at startup now. It goes away and comes back around 2k rmp.
Old Jun 11, 2021 | 08:39 PM
faisme111's Avatar
Could this be my SC? When warm and the idle is low it knocks. Increase the revs and it goes away increase more, past 2k and steady knock. I had the snout and bearings done and the rotors coated. Could it be the rotors?
Old Jun 12, 2021 | 08:43 AM
M. Stojanovic's Avatar
If you had an aftermarket solid SC coupler installed (instead of the genuine spring-loaded one), it is possible that the knocking comes from the SC. Remove its belt and run the engine to diagnose.
Kutthroat
May 13, 2021 04:30 PM
Steve W
Jan 29, 2018 11:02 PM
vdpnyc
Jun 11, 2017 01:18 PM
nd4spdlsc
US Western
May 16, 2017 05:07 PM
Steve W
Jan 3, 2017 10:15 PM
