Leaking Radiator
Old Mar 17, 2012 | 09:35 AM
Sparkers69's Avatar
Default Leaking Radiator
Chaps,
I have a very small/slight coolant at the bottom right of my radiator. If I was to add a stop leak additive how would I do that since I do not have direct access to the radiator? I am not losing coolant really - topping up once every couple of months and then I'm not adding much. Is it worth paying $700 for a new radiator or should I just wait a little longer to see if the minor leak gets worse?
Steve
Old Mar 17, 2012 | 01:02 PM
test point's Avatar
The drain plug for the radiator is at the bottom right inside corner. Before anything else I would verify that is the source of the leak. Most of the major auto parts stores will 'rent' you a pressure testing kit. Pump it up to 20 lbs and check for leaks. If it is the drain plug I would try a couple rounds of pipe joint tape before replacing the radiator.
Personally, I would never consider using a radiator stop leak additive on my car.
Old Mar 17, 2012 | 04:19 PM
yeldogt's Avatar
Best to pressure test to check location ....
I would never use any stop leak product for this type of problem.
You use stop leak when you have a leak and the car is worth $100.00 - and you hope to get another month out of it.
With all the hoses, pumps, valves and matrix -- you don't want to use any stop leak.
Old Mar 20, 2012 | 07:20 AM
Sparkers69's Avatar
It looks like it is the drain plug - plumbers tape sounds like a plan!
willtoliv
Oct 2, 2015 12:18 PM
Blaine Trarop
Sep 23, 2015 03:08 PM
Tipptone
Sep 16, 2015 07:39 AM
1100me
Sep 7, 2015 06:26 AM
