Left front headlight does not work
Old Mar 18, 2016 | 03:02 PM
tilbury's Avatar
Default Left front headlight does not work
The left front headlight does not work. I suspected the bulb but it lights when attached to 12 v. The right side works and the fuses are good. Wiring looks good. A couple times at night it has popped on for a couple miles then died out again. I can't even see how this could happen when looking at the wiring schematic. Any ideas?
Old Mar 18, 2016 | 03:16 PM
CharlzO's Avatar
Sounds like a possible loose connection in the wiring / plug somewhere, at least if it pops on and off every so often. Would have to backtrack through and see if you can figure out where though, I don't have much experience personally with the circuit, but just at a glance it sounds like something not making a good connection.
Old Mar 18, 2016 | 04:46 PM
Jhartz's Avatar
Do the other lights on that side work? If not, check the ground. If they work, loose wire. Either way, examine the fuses.
sjgh
Mar 27, 2016 10:31 PM
Atco
Mar 21, 2016 07:25 PM
jmarkitell
Mar 9, 2016 06:27 PM
edwardprince
Mar 11, 2009 04:35 AM
Dallas4lr
May 6, 2008 05:08 PM
