Left headlamp flicks
Old Dec 24, 2010 | 04:10 PM
Dunkit's Avatar
Default Left headlamp flicks
My headlamp low-beam on the left always flicker on my 2004 xjr. I think that it could be just a loose connection, is safe to try to repair it myself. It is an HID system which is HIGH VOLTAGE.
Old Dec 24, 2010 | 04:47 PM
JaguarXJR02's Avatar
you are dealing with an X351 this is the X308 part of the forum, none of our cars have HID headlamps except for custom installs. try a repost here: https://www.jaguarforums.com/forum/f...splay.php?f=28
good luck
Old Dec 27, 2010 | 06:45 AM
steve11's Avatar
ud
Yeah, you're on the wrong site, but - The most likely reason is a bad zenon. When they fail, they first start to flicker. I've corrected it 90% of the time with new bulbs. Yours takes the D1S style. These are expensive, but I've found very acceptable replacement bulbs on some of the Ebay stores. I believe the last set (pair) I bought for a customer on Ebay was $40. Factory bulbs are going to be well over $100 each.
Advisable to replace both at the same time as you'll never match color or brightness changing one bulb. If the bulb doesn't do it, then the only other cause is a bad ballast - brace yourself for that one.
rentzoo
Nov 10, 2015 04:56 PM
puddled
Sep 22, 2015 03:57 AM
Samheath100
Sep 17, 2015 10:03 AM
Tipptone
Sep 16, 2015 07:39 AM
Na5h
Sep 11, 2015 07:26 AM
