license plate and side marker lights out
Old Sep 18, 2014 | 10:37 PM
vdpsc's Avatar
Default license plate and side marker lights out
2001 vdpsc I replaced both license plate bulbs still no light. None of the side marker lights come on either. I pulled every 5 amp fuse in the trunk fuse box and all of them are good. I get an intermittent signal on the dash to check rear lights. When I first press the brakes it will come on. If I let off and reapply the brakes the warning often disappears. Any ideas???
Old Sep 19, 2014 | 07:35 PM
jimlombardi's Avatar
It could be a bad relay in the luggage compartment fusebox - Relay# 3 - license Plate light and the side marker lights:
Try switching Relay #3 and Relay #2.
Jim Lombardi
Attached Thumbnails license plate and side marker lights out-jaguar-xj-x308-relays-trunk-fusebox.jpg
Old Sep 20, 2014 | 09:15 AM
vdpsc's Avatar
That was the problem. I just pulled the car out of storage after about three years. I can drive at night now without worrying about getting pulled over unnecessarily! Thanks again.
Old Sep 25, 2014 | 11:01 PM
larney's Avatar
Here's my issue with the lic plate lights. I replaced both bulbs and when the trunk is open the left is on right is off. As I close the trunk the right comes on and the left one goes out. Yes the license plate lights. Not the interior trunk lights. So as I'm driving I have one license plate light on(right/pass). What gives?
Old Sep 26, 2014 | 04:55 PM
andrew lowe's Avatar
I would start by checking the wires that run along the right hand boot/ trunk lid hinge, under the plastic trim, as they are prone to braking.
Old Sep 28, 2014 | 04:34 PM
Look at forum thread:
https://www.jaguarforums.com/forum/x...issues-126542/
View posts #2 and #3.
Jim Lombardi
99xk8guy
Sep 29, 2025 10:51 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
raffoulig
Sep 8, 2015 01:56 AM
