long beep and won't lock when pressing door lock on remote
Old Apr 3, 2010 | 02:18 PM
newuser's Avatar
Default long beep and won't lock when pressing door lock on remote
It has happened a couple of times only for no apparent reason. I press on the remote to lock the doors and I just get a long beeeeeepppp, but it wont lock the doors. First time it happened I just got back in the car, started the engine and turned it off again then got out and pressed lock on the remote and it worked fine. I figured maybe it had something to do with a window not being properly closed but I tested it by leaving a window half way open to see if it would lock and it worked with no problems .
Old Apr 3, 2010 | 02:22 PM
TehNam's Avatar
Check to see if the trunk lid is closed.
Old Apr 3, 2010 | 02:46 PM
QuadManiac's Avatar
Put your key in the ignition, wiggle it around a bit and remove - then retry the key fob. the gate over the key slot can stick, and it's switch being still open tells the system that your keys are still in the ignition - it won't lock with the fob and warns you about it.
Old Apr 3, 2010 | 02:53 PM
newuser's Avatar
So it sounds like the key slot may need a little lubrication eh? Thanks for the info.
Old Apr 5, 2010 | 08:44 AM
Kansas99XJ8's Avatar
Had the same problem recently. Used a bit of electronic component cleaner spray (from radio shack) to clean it. Works fine now.
Old Apr 5, 2010 | 03:49 PM
newuser's Avatar
What did you clean? The ignition key slot or the remote? I don't think my problem is the remote.
Old Apr 5, 2010 | 04:13 PM
Sorry for the lack of clarity. The ignition key slot. The gate over the key hole that Quad mentions above sticks. I used electronic component spray cleaner to clean the gate, because I assumed that something like WD-40 or graphite lubricant spray might produce undesirable results.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
tberg
Sep 7, 2015 07:32 AM
