Low coolant light keeps reappearing after top off with no visible leaks.
My 1999 Vanden Plas SC with 96k miles started displaying a low coolant light. After the first top off it went away for about 2 days. Then reappeared. Top off again and another 2 days it appears. There is no visible leak and the light temporarily goes away after a top off. I noticed a hissing noise after the last top off but it was coming from inside the radiator. My friend said air could be stuck in the system. I have no idea what could be causing this. Any help would be appreciated.
Your problem is obviously not in the coolant light but in the coolant loss. I don't think the hissing sound you heard is from "inside" the radiator but possibly coming from a small coolant leak somewhere in that area. Inspect carefully the main radiator, the charge cooler radiator, the water pump and the associated hoses.
Every time this happens to me that I keep losing coolant and keep adding coolant it’s from a head gasket? Slow leak I never get lucky what’s your oil to see if water is getting in it ..
I thoroughly inspected all the hoses and even took the fan off the radiator to find no leaks. I ended up doing a heavy duty coolant flush. There was loads of gunk in the system and a lot built up around the bobber in the reservoir tank. I flushed it, put new coolant back in, drove it about 100 miles with no light so far.
My guess is that some point during previous ownership multiple types of coolant were used to top it off but it was never flushed causing the bobber to have so much gunk on it that it would stick to the bottom.
Peter Jones
Aug 24, 2016 08:12 PM
