Low Washer Fluid warning
Old Jul 1, 2010 | 11:03 PM
marktmv's Avatar
Default Low Washer Fluid warning
2001 XJR
Low Washer Fluid warning stays on constantly, any ideas on possible causes? Does the washer fluid reservoir have a sensor built in?
The washer itself works fine.
Mucho thanks in advance
Old Jul 6, 2010 | 02:53 PM
Stu 1986's Avatar
Do you have enough fluid in the said reservoir? You're lucky! Mine doesn't tell me when it's low it runs out just when I really need it!! :P I think it may be a sensor issue also, I'll take a good look when I drop the tank out of mine because it has spung a leak and I need the seal it.
Old Jul 7, 2010 | 07:21 AM
Sean B's Avatar
Originally Posted by marktmv
2001 XJR
I've had this, open the header, there's a float, it's probably stuck in the low position, i just slid the float up and down on its shaft with my finger until it was moving freely, no light afterwards. Another possible cause is a bad sender, this connects underneath the header tank, and pops out. Swop for a good one if fingering doesn't work.
Old Jul 8, 2010 | 03:01 PM
Stu 1986's Avatar
Don't be dirty!! Only Messin!!
Whilst we're on the matter is the tank easy to remove? As I mentioned I have a leak in mine I need to fix and I aim to get the fluid level sensor working again also whilst I'm there.
Ta, Stu.
aholbro1
Dec 29, 2024 06:46 PM
pnwrs2000
Jan 15, 2018 07:20 PM
johndahlheimer
Sep 16, 2015 05:44 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
giandanielxk8
Sep 6, 2015 07:21 PM
