MAF Sensor
Old May 16, 2015 | 07:07 PM
Presence's Avatar
Default MAF Sensor
I just pulled this out of my 01 XJR. Everything I've read says to spray two wires that apparently should be seen, but I see none. If I look up into the sensor, I *think* I see filaments but I'm not sure. Does this sound normal, and should I spray the cleaner up into it?
Attached Thumbnails MAF Sensor-20150516_184211.jpg   MAF Sensor-20150516_184200.jpg
Old May 17, 2015 | 12:26 AM
capitaineInsano's Avatar
The little black teardrop thing on the end of the thin piece of metal is the sensor. It should be slightly see- through (but still very dark). If it's opaque (most likely on one side), then it's dirty, and you can clean the glass and the metal with your spray maf cleaner.
Poet
Feb 7, 2025 02:18 PM
Dave1109971
Dec 15, 2015 06:16 PM
carl purchase
Oct 14, 2015 06:14 PM
Dave1109971
Sep 30, 2015 11:04 PM
Doug S
Sep 30, 2015 02:03 AM
