Metalic chatter at start up for a second or two, 2003 XJ8 base.
Old Feb 27, 2018 | 10:47 AM
Jhartz's Avatar
There is a great tutorial out there (Xk8 forum), plus about four or five really good threads that discuss lots of issues with doing the secondaries: removing dip stick tube, taking pressure off camshaft, etc. Just secondaries is really easy after you read the procedures over and over and memorize them. Doing the primaries is maybe way too hard for an apartment parking lot.
Old Mar 8, 2018 | 11:54 AM
RSpi's Avatar
Thank you very much sir.
Old Mar 9, 2018 | 11:34 AM
RSpi's Avatar
Will these eBay parts work? Or should I seek better quality parts?
https://www.ebay.com/itm/Jaguar-Ford....c100675.m4236
Ordered all OEM gaskets and the tool set already.
Old Mar 9, 2018 | 11:58 AM
Sean B's Avatar
RSpi - have you pulled the timing cover before spending any more money?
Can you give me the engine number? it's stamped on a stiffening rib cast into the side of the engine block along with bearing codes - it should look like a date backwards....e.g. MB0109161430. It may need to be viewed from underneath the car. There's a number of items attached to the engine that can make a noise on startup, VVT being one.
Old Mar 9, 2018 | 12:22 PM
RSpi's Avatar
No I have not pulled the covers.
I'll go look for it. Which side of the engine should it be on?
Old Mar 9, 2018 | 03:34 PM
Sean B's Avatar
looking at the front of the car it's on the right hand side. A picture always helps, this is a late model AJ27S engine and yours being an 03 should have the bearing codes above and the engine birth date below in the same place.
Attached Thumbnails Metalic chatter at start up for a second or two, 2003 XJ8 base.-dscf3927-copy.jpg
mick99
Jul 14, 2017 09:31 PM
razorboy
Feb 21, 2017 09:55 AM
Righand
Nov 29, 2010 06:56 PM
julio pena
Jun 17, 2009 09:37 PM
