Missing Coolant
Old Jun 9, 2008 | 12:39 AM
alckc's Avatar
Default Missing Coolant
I have a 98 VDP with 132,000 miles. For the past month I have notice that my coolant has been mysteriously disappearing. Each morning I have to put in about half a pint, sometimes a pint if I drive a lot. I do not see any drips on the ground but do smell anti-freeze. I replaced the water distribution pipe last summer. The water pump has no unusual sounds and spins evenly. However, I do see gunk around the water pump side of the lower front of the engine.
Does anyone have any ideals or suggestions.
Old Jun 9, 2008 | 01:08 PM
KAZsam's Avatar
Default RE: Missing Coolant
It seems you are losing coolant when you are driving not parked so its probably the water pump. Is your oil nice and oily or foamy
Old Jun 11, 2008 | 11:25 AM
alckc's Avatar
engine oil is good. no signs of water. i pulled the plugs and they are dry, too, so no cracked block.
i took the car into the shop and they did a pressure test. they said that there was no major leak. (i could have told them that) i assumed they inspected the water pump, but who knows. i many replace the thermostat, maybe it is sticking a little.
Old Jun 12, 2008 | 08:10 PM
jag_genius's Avatar
water pump.. breather hole.. the drizzle out thru this hole.. needs a water pump
Wahooesprit
Dec 23, 2019 02:01 PM
duecedriver
Dec 25, 2015 11:47 AM
Peeam
Sep 22, 2015 05:15 AM
Peeam
US Northeast
Sep 21, 2015 09:43 AM
jimmiejag
Sep 9, 2015 02:56 PM
