moonroof small piece
Old May 30, 2009 | 09:48 PM
cadrad's Avatar
Default moonroof small piece
Hello- New to the forum with a 1998 xj8 L. When I bought it the small piece on the back of the moonroof was nowhere to be seen. Following the adivce from a post on here, I was able to fish it out with a coat hanger. So here is my question. It appears to be attached to a sliding track. There are small holes in a bracket on each side that protrudes from the top. There appears to be corisponding posts in the main part of the moonroof, but I have no idea how to attach them together. I also don't see how the tilt would work if I did manage to attach them. Can anyone explain? Thanks in advance!
Steve R.
P.s. It did not come with floor mats anyone know where I could get a nice used set? The interior is the tan color (cashmere?) (not ivory)
Old May 30, 2009 | 10:17 PM
stran0020's Avatar
I have the same problem! my friend thought it was a sunroof and tried pulling that small piece back :/ could you please direct me to where i can find directions on how to fish that piece out. thanks in advance
Old May 30, 2009 | 11:26 PM
cadrad's Avatar
Default Re: moonroof small piece
I found the info by using the search this forum feature and then typing in sunroof. once it pulls up the results it is in the replies to "1999 Jaguar XJ8/ Sunroof Problem" . I found that I could fit my hand in the slot once I got it forward a little bit ( using an unbent wire hanger) and slide it out the rest of the way. Currently, I havi it positioned correctly and am not using the roof until I figure out how to attach it back to the main section.
hoodun
Nov 20, 2022 02:35 PM
Jagzzz
Aug 8, 2021 02:45 PM
bdboyle
Sep 16, 2019 05:58 PM
jagxk2008
Feb 4, 2016 09:53 AM
jessejamestw23
Sep 26, 2015 03:57 PM
