This must be the easiest/most obvious response ever.
Old Sep 4, 2019 | 04:00 PM
sayhitobaldy's Avatar
Default This must be the easiest/most obvious response ever.
I have what must be the dorkiest question;
Removed the interior cowling just inside the grille to replace a headlamp. To do so, I removed six or so of these plastic bolts...they unscrewed right out.
Now, looking to screw the cowling back on, none of the bolts seem to fit their respective holes? How do I screw these things back in? Am I having a brain fart preventing me from seeing the obvious?
1969 Signal Red E-type FHC
1998 Amaranth Pearl XJ8 VDP
2005 SeaFrost XJ8 VDP
1969 Primrose Yellow MG Midget
Old Sep 4, 2019 | 04:19 PM
Oops--posted to wrong thread.....X308 instead of X350...problem is with my 2005, not my 1998. I'll delete this, if I can find out how.
Old Sep 5, 2019 | 11:58 PM
Iconoclast's Avatar
Are you sure they do not just push in? That is how the similar, engine cover fasteners work in my 2000 XJ8. (X308) Looks like a screw but, is not a screw.
Old Sep 6, 2019 | 01:54 AM
JagV8's Avatar
(Just for completeness, as the info is in the other thread(s)...)
Once removed, they unscrew/press out, so the splayed part is not longer splayed. Then they slot in and you screw the central part in (causing a re-splay that holds the parts together).
Probesport
May 31, 2025 05:33 AM
BillDJohnson
Oct 8, 2018 08:07 PM
BruceG
Aug 13, 2013 05:39 AM
wildcard
Sights N Sounds
Mar 19, 2010 01:34 PM
