My 00' XJR Refresh
Old Aug 24, 2012 | 01:39 AM
  #41
XJR Prototype's Avatar
I'm going to try it on another computer tomorrow.
Old Aug 24, 2012 | 04:01 AM
  #42
plums's Avatar
Forgot about that problem. There seems to be a bug in the code if you look at the source.
Open IE and navigate to the following location:
H:\jag\jepc\JEPC\applications\JEPC\html\JEPCLogin.html
The bolded bit is what is important .. the rest depends on where you have JEPC installed. Once you are there, bookmark the location to be able to start there again. The login is ADMIN, password 123.
Depending on your security settings, it may keep prompting you on every page about activex permissions. Just click ok everytime.
Old Aug 24, 2012 | 11:25 AM
  #43
I got it to work on another computer I have with windows 7
Needed a fresh day, got the newer knock sensors on the way as well.
Old Aug 25, 2012 | 06:10 PM
  #44
I'm at the mercy of the parts guys to ship my stuff now.... so.. I got to cleaning everything I could... good as new.
Going to get down in the valley of the motor next and make it look new again.
Really wish someone local could clean the supercharger up for me, don't wanna get anything harmful in there... probably just leave it alone until I upgrade later...
Part numbers for everything i replaced...
Old Aug 28, 2012 | 06:34 PM
  #45
Let's just say I will not allow anything with a spec of rust back into the engine bay... no sir!
Airbox mount refreshed...
Fuel injector harness bracket got refreshed, as well as those dirty injector plugs! yukkyyy
Tops of the injectors got a good cleaning after this picture, but the bolts holding it down aren't rusty anymore!
I won't have to worry about those hoses anymore... put in some braided reinforced silicone hose
And just because I'm picky I had to go get the correct worm clamps... the stock ones aren't quite big enough and are a hassle in those tight areas...
That's about it, I took the intercoolers to a local machine shop to get them cleaned so they will be fresh, picking them up tomorrow... then I'm still at the mercy of slow parts guys to ship stuff out
Old Aug 29, 2012 | 03:14 PM
  #46
Just wanna post and say the SMP KS305 knock sensors are actually the OEM Denso just reboxed Score!
That should save you guys some loot.
Old Aug 30, 2012 | 08:24 PM
  #47
plums's Avatar
Supplier?
Old Aug 30, 2012 | 08:32 PM
  #48
Post number 32
amazingsavingsautoparts.com
Old Aug 31, 2012 | 08:59 AM
  #49
sbreeden's Avatar
Hey XJR Prototype,
I think I remember you from BimmerForums, if you are the same guy, that XJR is in for a hell of a make over.
Welcome to the board.
Old Aug 31, 2012 | 09:41 AM
  #50
Yes, yes it is
Old Aug 31, 2012 | 01:02 PM
  #51
I can't express to you my frustration and amount of hours i have into getting the intercoolers completely clean....
Parts come in UPS today from Nalley ( they honored the forum discount ) and she will finally be put back together... just wanna drive it for awhile man!
Old Aug 31, 2012 | 05:42 PM
  #52
WaterDragon's Avatar
Looking really good
Old Sep 1, 2012 | 09:37 AM
  #53
Azeebabee's Avatar
Watching and waiting for the next installment.
Old Sep 2, 2012 | 04:59 PM
  #54
Just a fair warning... Nalley isn't fast and they forget parts, so even tho these were overnighted I'm still missing the coolant outlet seals, so they had to ship those as well... on a holiday weekend... it'll be tuesday before it runs, if you use them for the discount they offer, talk to anyone else but Paul. That's all I have to say about that.
So while I'm waiting I've put everything else back together.... First I knock the crud/rust off every bolt the job takes and add a 650deg engine paint... kinda a zinc look... ( i wish i had a real zinc refinisher...ill do them over later...)
Updated Duct Seals...
New bypass valve hoses, gaskets... keep it clean!
Man I can't stand ugly!
Cleaned up the valve cover and installed the new gaskets... The Victor Reinz works great...
Valve cover bolts got refinished and new gaskets installed...
I was told by the previous owner the timing tensioner stuff was already done... annddd.. nope. That's next.
Added more electrical tap to the wires in here... it was too sloppy for my taste...
anddd.. wala! Looks so much better...
NNE302IAC x 1
KSC137624 x 1
C15644 x 1
NCC7735BA x 1
AJ86925 (Updated duct seals, you may need to order the correct plates too!) x 2
NCC3018AB x 2
NCA2268CA x 2
NCC7754BA x 1
NCC2213AC x 2
JWV130001 x 1
I'm now moving onto the drivers side... Happy labor day weekend!
Old Sep 4, 2012 | 03:06 PM
  #55
Well, STILL waiting on seals... says they come in tomorrow.......
Meanwhile.. I picked this gem up... It's getting sent out to be recovered in some new material and stitching
My wood steering wheel is for sale if anyone wants it, just have to wait on this to come back first.
Old Sep 5, 2012 | 02:37 PM
  #56
Coolant outlet seals came in and got her started up... runs better than new now.
Only leak is the outlet on top of the water outlet pipe to the fill tank Gonna have to do something about that and then flush the coolant once or twice so that's fresh too.
Feels good to have it back and clean tho
Old Sep 5, 2012 | 04:39 PM
  #57
Alvin Burns's Avatar
You are one meticulous, competent and dedicated workman. Impressive, indeed! Thanks for sharing your adventure with us. The detail pictures are just great.
Old Sep 5, 2012 | 06:48 PM
  #58
I have an OCD problem, can't help it.
Old Sep 6, 2012 | 01:42 PM
  #59
Gotta start the wheels off detail the right way....
Will gladly trade these for some Detroit's though
Old Sep 6, 2012 | 03:17 PM
  #60
Safi's Avatar
i truly admire your dedication to cleaning up your Jag, its truly inspirational to all of us that some average person can do anything and everything to our cars, keep up the work, i look forward to the end result
