My tips of how to make elbow easier to install and remove
Old Oct 13, 2012 | 11:07 AM
WaterDragon's Avatar
Default My tips of how to make elbow easier to install and remove
I found a few ways to make removing and installing the intake elbow MUCH easier.
I found it "rather difficult" to get the intake elbow out and back in the first time so I made the following minute mods:
Wherever the metal was shiny from rubbing I ground away a tiny bit (maybe only 1 mm) of material and that made the elbow drop right in vs really having to cuss at it. I also slightly rounded off the bottom of where the side bolts go in to help guide it into place. I left the dimension of left to right the same, just rounded the bottoms-see photos.
Also, the two hoses attaching the EGR benefited from being cut down a little bit to give a small amount of wiggle room for fitting. I also changed the clamps to regular hose clamps that are accessible from above with a small 1/4 drive socket when installed. I just find this was easier than the stock spring clamps to get back on correctly.
Along these same lines I replaced the clamp on the hose thingy near the front of the engine (see photo) with a regular hose clamp for the same reason.
Now the elbow drops right in without fuss.
Attached Thumbnails My tips of how to make elbow easier to install and remove-2012-08-31-18.13.19.jpg   My tips of how to make elbow easier to install and remove-2012-09-25-20.34.38.jpg   My tips of how to make elbow easier to install and remove-2012-09-25-20.34.48.jpg   My tips of how to make elbow easier to install and remove-2012-09-25-20.35.07.jpg   My tips of how to make elbow easier to install and remove-2012-09-25-22.21.36.jpg
SD96XJ6L
Jan 12, 2022 04:30 AM
afterburner1
Dec 16, 2015 12:12 AM
philwarner
Sep 5, 2015 10:05 AM
davidladewig
Sep 3, 2015 06:32 PM
Dallas XK8
Sep 3, 2015 12:17 PM
