Mystery Knob Found. Help Solve.
Old Apr 19, 2016 | 12:46 AM
ratgawd's Avatar
Default Mystery Knob Found. Help Solve.
Found a small knob object on the driver side floor board. Any help? I've attached images.
Attached Thumbnails Mystery Knob Found. Help Solve.-img_4174.jpg   Mystery Knob Found. Help Solve.-img_4175.jpg   Mystery Knob Found. Help Solve.-img_4176.jpg   Mystery Knob Found. Help Solve.-img_4177.jpg
Old Apr 19, 2016 | 04:02 AM
Addicted2boost's Avatar
It goes under the gas pedal. I'm 'fairly certain' it was adjusted to a predetermined value using a scantool to prevent either overly opening the throttle blade and/or preventing throttle cable from stretching. The previous models 95'-97' X300
(other years/models also) used this same setup with the exception that it had a transmission kick down switch built into it. Yours is just an adjustable stopper basically.
Old Apr 19, 2016 | 07:52 AM
avern1's Avatar
That is the head off of the Kick Down Switch. I have attached a scan of the tech manual showing it's location.
springer
Apr 22, 2016 11:05 AM
jehart49
Apr 20, 2016 11:39 AM
jagtoes
Apr 15, 2016 06:38 AM
Johnken
Apr 14, 2016 12:34 PM
JigJag
Apr 13, 2016 05:24 PM
