N/A cams in a S/C car
Old Aug 21, 2012 | 10:57 AM
johnnie ryall's Avatar
Default N/A cams in a S/C car
Does anyone know if you can use naturally aspirated cams in a s/c 4.0l? i have the thrust piece broken off my s/c intake cam on Bank 2. I have a set of n/a cams to use if i can. The part #s are different for n/a vs s/c though. The specs says the s/c valves open and close the same as the n/a cam does in the retarded position, but maybe the lift or something is different?
Old Aug 21, 2012 | 01:59 PM
Sean B's Avatar
it's possible the profile is different on NA because of VVT. Can you compare the profiles, maybe take same measurements?
Funny that the 3.2L version available in the UK share the same part number, and don't have VVT.
I've never heard of a cam breaking, was there any reason for this?
Old Aug 21, 2012 | 02:42 PM
dsnyder586's Avatar
I have cams from a 1998 XJR for $40ea including shipping if you end up needing them.
Old Aug 21, 2012 | 03:08 PM
Cambo's Avatar
Or you could try retrofitting the VVT
https://www.jaguarforums.com/forum/s...23/#post563673
Old Aug 21, 2012 | 04:04 PM
I snapped the round part behind the pulley that is machined to ride against the side of the 1st cam journal. there is another one like this on the other side of that journal. it looks to be for the front to rear thrusting of the cam. it will likely be ok if i deburr any sharp edges. If the n/a cams were the same id use one them. I did it trying to **** the cam up to sneak a new secondary chain on. ill keep the 98MY cams in mind for $40
Old Aug 22, 2012 | 04:09 AM
plums's Avatar
If you can get a degree wheel onto the cam and a dial indicator, you can measure the lobes through a full rotation and know for sure.
Geofflvmyjag
Dec 16, 2016 11:26 AM
Drew2006
Aug 28, 2015 04:22 PM
peterg19
Aug 28, 2015 08:42 AM
stetson1
Aug 27, 2015 07:49 AM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
