Nav button
Old May 1, 2011 | 06:25 AM
ant17's Avatar
Default Nav button
I see a NAV button on my car center.
Does this work? or do I have to be subbed to some service?
I pressed it and nothing happens.
tia
Old May 1, 2011 | 09:51 AM
Boomer from Boston's Avatar
If you don't have the navigation system, that button does nothing and it's only function is to impress your friends. Look in the trunk/boot on the left side - If you see a stack of two black boxes, you have Nav. If you only see one black box (CD changer) you don't. Navigation was extra cost, even on the Vanden Plas.
Old May 1, 2011 | 12:25 PM
Sean B's Avatar
the nav is DVD based, the player is located as boomer suggests in the boot, it's situated underneath the cd changer. If nothing happens you've not got it installed, although checking the boot loom around the cd changer, you may find your car is equipped with a nav loom, in which case you can buy a nav dvd player and plug and play. You would have to buy the correct part number for model year, and the dvd disc.
Old May 1, 2011 | 01:06 PM
Stu 1986's Avatar
And you will find it is as good as a chocolate ashtray. Better using a modern up to date a cheaper SatNav than trying to get the car's one to work. It only works with the stereo on and whenever it's about to say anything it chimes that same "Bong" sound you hear when the seatbelts sign is lit on an aeroplane.
Old May 1, 2011 | 08:18 PM
ant17's Avatar
Thanks all.
So my Garmin would do better.
I do have unlimited lifetime maps and traffic. garmin 1450
Finbarr1975
Sep 5, 2025 08:38 PM
Paora
Feb 4, 2021 12:36 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
Finbarr1975
Oct 4, 2015 05:32 PM
