Need to add coolant every 2 warm weather months, is that normal?
Old Sep 22, 2013 | 09:44 PM
vdpnyc's Avatar
Question Need to add coolant every 2 warm weather months, is that normal?
It seems to be escaping out the overflow/over-pressure valve at the front-center of the engine block, triggering the low-coolant message about every 60-days during warm weather, when I add coolant it only takes about 1/3 gallon but that satisfies the low-coolant sensor for another couple months
Old Sep 23, 2013 | 04:31 AM
test point's Avatar
Not normal but not unusual. The coolant system should not loose fluid and if it does there is a leak somewhere that needs repair. A number of auto parts stores will loan you a pressure test kit to make finding the leak easy. Careful selecting the reservoir cap from the many provided. You need one that seals the reservoir from the overflow system. I found that only the universal fitting worked. The leak problem should be evident under pressure.
I am not aware of an over pressure valve at the front center of the engine. The over pressure issues is handled by the reservoir cap.
dsnyder586
Dec 29, 2024 07:39 PM
jimmiejag
Sep 9, 2015 02:56 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
Xkr x100
Sep 6, 2015 08:50 AM
