need airbag flash code
Old Dec 13, 2011 | 06:47 PM
wesmc2's Avatar
Default need airbag flash code
I guess it is in JTIS..heck if I can find it.
I am getting a single flash...1
then light stays on.
Also..occasionally if I use the cruise control the restricted performance light comes on but the car doesn't enter the safe mode. I still have all my RPMs. Only the cruise is disabled.
If I shut the car off and then come back to it the next day all is fine, and stays fine as long as I don't use cruise.
Old Dec 13, 2011 | 07:51 PM
test point's Avatar
Here are the airbag flash codes:
https://www.jaguarforums.com/forum/a...lash-codes-pdf
Old Dec 14, 2011 | 01:25 PM
xjrguy's Avatar
You've got a brake pedal switch getting flaky on you. Code P1571. Shows a "Restricted Performance" message and disables the cruise control for the remainder of the key cycle.
Cheers,
Old Dec 14, 2011 | 01:34 PM
Gus's Avatar
Gus
Cheers,
Old Dec 15, 2011 | 11:36 AM
wesmc2's Avatar
thanks so much...I'll get on it. You guys are the best.
Old Dec 15, 2011 | 11:59 AM
motorcarman's Avatar
The X308 does not have flash codes.
The 1997 to 2002 X100 do not have flash codes.
Later Jaguars have DTCs and flash codes.
XK 2003MY onward, X202 S-Type 2003MY onward, New XJ X350 2004MY onward etc.
bob gauff
Jpav27
Jul 31, 2022 06:43 AM
Iain Yates
Sep 16, 2015 06:48 PM
Johnken
Sep 15, 2015 05:46 PM
tonyforman
Sep 10, 2015 07:23 PM
mrplow58
Sep 9, 2015 11:27 AM
