Need help with hitch wiring please!
Old Mar 2, 2013 | 11:13 AM
meaculpa's Avatar
Default Need help with hitch wiring please!
I'm getting a hitch installed on my 2001 XJ8 VDP. I bought the wiring kit (Curt Powered Taillight Converter part # 56146) and I need some help with the color codes at taillights. I got six wires going to the vehicle taillights (black-battery, green-right turn, red-stop, yellow-left turn, brown-tail/parking and white-ground) - I need the coresponding wire colors for vehicle.Thanks
Old Mar 5, 2013 | 07:21 AM
meaculpa's Avatar
Any help with an electrical diagram for tail lights (01 VDP)Thanks
Old Mar 8, 2013 | 04:51 PM
meaculpa's Avatar
Exclamation
I'm going NUTS !!!
Here's the wiring on the vehicle by colors:
LEFT TAIL LAMP:
Stop - Blue
Tail - Red
Left Turn - Green/White
RIGHT TAIL LAMP:
Stop - Orange/Yellow
Tail - Red/White
Right Turn - Green/Orange
The tail light converter that I got from CURT (part # 56146) has these wires going to the ones above:
+12v battery - Black
Right turn - Green
Stop - Red
Left Turn - Yellow
Tail - Brown
Ground - White
Which one goes where? Am I missing something? It does not make any sense PLEASE HELP
Old Mar 13, 2013 | 06:31 PM
Cameron Stickley's Avatar
I might be wrong but I don't think you need the converter from what you described
Old Mar 13, 2013 | 06:36 PM
4 wire plug for trailer hitch is brown is marker lights
Green is right signal
Yellow is left signal
White is ground
And you do need the converter sorry. I was looking at the wrong model of car.
Old Mar 13, 2013 | 06:46 PM
Yellow = green white left side
Green= green orange right side
Red= left blue or right orange/yellow any side doesn't matter
Brown= left red or right red/white doesn't matter
White = ground chassis
Black = battery positive
Hope that helps
Old Mar 13, 2013 | 07:51 PM
plums's Avatar
Look at your wiring diagram again.
It may be preferable to use the built in trailer lighting harness if the car is equipped with one.
Old Mar 16, 2013 | 07:34 AM
meaculpa's Avatar
Thank you everyone and especially Cameron Stickley Great job!
Old Jul 22, 2013 | 09:56 PM
jimdav66's Avatar
Hi, not sure if I'm alone on this, but I'm trying to install a trailer wiring kit on my 04 xj8. I've located the hot side to the turn signals and running lights (using the rt rear side marker). I can't figure out the brake lights. The LEDs are the issue. Everything runs through the rear computer control module, making it tough to sort out.
Any thoughts on how to fix this issue?
thanks.
Jim
Poet
Feb 7, 2025 02:18 PM
jagent
Jun 5, 2022 02:18 PM
Rocky15
Sep 28, 2015 04:59 PM
driver safz
Sep 26, 2015 06:01 AM
swetnK
Sep 24, 2015 07:55 AM
