need help with t-chain tensioner
Old Oct 4, 2013 | 06:07 PM
junioramy1's Avatar
Default need help with t-chain tensioner
i need help choosing the correct timing chain tensioners for my 2000 jaguar xj8 . i am going to replace the original plastic ones for the metals ones so can somebody post a link to the ones i should get or a pic of how they should look cause i seen a few but i don't want to end up getting some really poor quality aftermarket ones but not too expensive just reasonable thanks!
Old Oct 4, 2013 | 06:32 PM
here is the link from the how to's portion of this section - scroll down to the embedded links and it is the 5th one
https://www.jaguarforums.com/forum/x...k-links-20090/
if you can't find there - here is the link to the actual download:
http://www.mediafire.com/view/?wnuacwgt22023o9
Old Oct 4, 2013 | 07:33 PM
RJ237's Avatar
I and many others used tensioners for the '01 Lincoln LS, same part but cheaper. Order 2W9Z6K254BA and 2W9Z6K254CA and four shorter bolts W500301S300? ( someone please confirm). I ordered from sunroardfordparts.com. You need felpro gasket set VS 50724 R which you can buy at Autozone, etc.
mikiep
Dec 20, 2019 07:37 PM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
millertic
Sep 30, 2015 08:11 PM
JAMES1944
Sep 29, 2015 11:58 AM
