need a new Mass flow meter MFS
Old Nov 13, 2011 | 05:27 PM
vincent661983's Avatar
Default need a new Mass flow meter MFS
Hi to all, I took my car 2000 XJR to Jagpro,Bellmore NY and Martin told me that my check engine light was related to the Mass flow meter.
I actually replaced one(used)last year as had shifting problem,but Martin said that I had to install a brand new.My question -is it ok to replace an aftermarket one from autozone since the price quoted only around 150 , that is way cheaper or still OEM for jaguar rules?
Martin also said about the TPS issue, he said hopefully the issue was not on the
throttle-body, but perhaps just wiring/electronic
please share some thoughts with me
Old Nov 13, 2011 | 05:39 PM
Sean B's Avatar
Hi - what TPS issue?
changing the mass air flow sensor can help if the car repeats codes related to lean/rich running etc, what is the car saying with regard to swapping MAFS? codes thrown?
Need more info!
Old Nov 14, 2011 | 09:39 PM
Sean,I really do know about the codes,
by the way, I still cant let the caliper upgrade go away from my dream
Old Nov 15, 2011 | 06:07 AM
Sean B's Avatar
Can you buy a cheap code reader and report back?
If you're still dreaming, buy these and bolt them on! you'll need discs Good luck
Jaguar XJR v8 supercharged brembo type R break 4 pot calipers full set | eBay
Old Nov 15, 2011 | 08:18 AM
SteveM's Avatar
Those calipers are from an X350 XJR/ S type R and won't bolt up to the X308. I think he already made that mistake once.
Old Nov 15, 2011 | 10:32 AM
Sean B's Avatar
I only looked at the bolt centres' on the front....oh well.
I do know where there's an X308 set, but don't know the condition, and shipping to the USA would be a bend over exercise...I can inquire Vincent?
Old Nov 19, 2011 | 09:54 AM
Steve knows me the best
vwbusbits
Oct 13, 2015 03:43 AM
o1xjr
Oct 1, 2015 09:46 AM
goingjag
Sep 30, 2015 09:27 PM
ziondio
Sep 29, 2015 01:58 PM
