In need of a solution
Old Dec 30, 2025 | 01:59 PM
Ace VDP's Avatar
Default In need of a solution
I discovered a fuel leak from here. What can cause this besides a bad gasket. Thanks.
Old Dec 30, 2025 | 04:29 PM
Peter_of_Australia's Avatar
I'd start with swapping the gasket (assuming that there is one) and go from there....
Don't drive, while the fuel is leaking... - or alternatively always take some sausages and long sticks along with you for a BBQ on the roadside...
Old Dec 30, 2025 | 07:03 PM
Parker 7's Avatar
Fuel leak on top of any engine equals do not drive
Alot of early Jaguars suffered the fate of a smoking hole in ground
You can leak check it by jumpiring the hot at all times # 1 fuel pump relay and plenty of the cheapest kitty litter to keep fuel away from truck area or a hill
Pin 3 ( hot at all times ) to 5 ( to fuel pump )
Use medium gauge wire with blade type wire ends , the auto parts store can make one for you
Old Dec 31, 2025 | 03:38 AM
BringBackFord's Avatar
Is it in the fuel pressure regulator?
Old Dec 31, 2025 | 08:27 AM
Parker 7's Avatar
X100, X308 - Fuel Pressure Regulator - (NCA3007CA)
Instinct Racer
E type ( XK-E )
Mar 2, 2023 01:13 PM
Vee
Jan 18, 2023 01:41 PM
ballast
Oct 5, 2021 08:24 AM
Vee
Sep 18, 2021 10:37 AM
Vacajun
Aug 3, 2017 08:48 AM
