need some rear suspension bush dimensions
Old Jan 26, 2015 | 09:00 PM
plums's Avatar
Default need some rear suspension bush dimensions
If anyone has easy access, I would like to get the thickness and diameter of
the bushings in the strut assembly at the rear of the IRS. In the picture it
is the "birdcage" assembly at the rear of the carriage which has two bushings
at the bottom of the differential and two in the outriggers.
I am trying to figure out if they are the same size as the X300 bushings for
their equivalent dogbones. Poly bush vendors list them for the X300 but
not the X308 and it may simply be a matter of them not knowing.
To any X300 owners stumbling by, that birdcage would seem to be a
way to improve suspension location since it is is single fixed set of
points rather than the two dogbones that can move independently.
I think the late XJR/6 may already have it, but not the others.
Attached Thumbnails need some rear suspension bush dimensions-x308-irs-b.jpg
GordoCatCar
Jan 2, 2017 01:10 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
